talk 当前数据包标识,固定为locationState
"position_x": 0,
"position_y": 0,
"position_theta": 0,
"mapname":"map",
"confidence": 0.0632394403219223,
"currentLayerID": -1,
"errorState": "",
"laserHZ": 9.856913747827345,
"laser_inrange": 0.5615,
"laser_sizes_1": 6000,
"laser_sizes_2": -1,
"laser_time": 1722581955.4374952,
"map_load_time_cost": 0.43245387077331543,
"map_resolution": 0.019999999552965164,
"map_state": 1,
"map_x_m": 33.07999801635742,
"map_y_m": 43.47999954223633,
"max_ratio": 2631,
"min_ratio": 0,
"talk":"locationState",
"odomErrorRecovery": 0,
"odomHZ": 60.819942135568056,
"odomMarkUpdate": false,
"odom_dif_time": 0,
"odom_time": 1722581955.4374952,
"outline_match_acted": false,
"process_hz": -1,
"ref_match_acted": false,
"ref_match_type": -1,
"ref_scan_match_change": null,
"reflector_num": 2,
"reflector_used": -1,
"refmatch_error": -1,
"res_1": -1,
"res_2": -1,
"result_type": 0,
"time": "06:59:15",
"validPoints": 540,
"validResponse": -1,
"version": "20240420"
